Peghead Question
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=15654
Author:  RaymundH [ Fri Feb 01, 2008 9:57 am ]
Post subject:  Peghead Question
Hello!
After doing four headstocks with a standard paddle style headstock I decided to try a slotted pehead on my current L-00 "style" build.
My issue is in regards to my slots. They are standard rounded on each end but I just realize that I will need to make "sting ramps?" at the bottom of each slot to allow the strings to access the tuning machines. Is there a standard measurement for this or is it an eyeball it thing? (Using Grover Sta Tites for my tuning machines)
Thanks!
Ray
Author:  LanceK [ Fri Feb 01, 2008 10:32 am ]
Post subject:  Re: Peghead Question
I just eye it, and when I'm getting close I place a nut at the end of the FB and then put a straight edge on the nut to the first post hole and verify that I am clearing the floor of the ramp.
Author:  JBreault [ Fri Feb 01, 2008 10:37 am ]
Lance, does that angle change after you slot the nut?
Author:  LanceK [ Fri Feb 01, 2008 10:56 am ]
Good point, yes you want to use something (anything) that would represent your final string height, or at least close to final height. ;)
Author:  Steve Kinnaird [ Fri Feb 01, 2008 11:04 am ]
The terminus of a Martin ramp is almost touching the nut.
At least my little 00 is done that way.
I think it looks good, and you sure avoid the embarrassment of strings digging into your headstock finish.
Author:  Laurent Brondel [ Fri Feb 01, 2008 1:00 pm ]
Slotheads usually have a slender angle, around 12º vs. 18º for Martin I think. Some Spanish guitars have almost no angle on the peghead, which solves the issue of the ramp being too shallow.
